connection issues
I have Arlo doorbell and 5 cameras. I had to replace the base station and was able to reconnect the doorbell. For some reason, it is not allowing me to connect the 5 Essential cameras. Any ideas?
To be clear, these are the original Essential (Gen. 1) cameras? The new Gen. 2 cameras currently cannot be connected to a hub or base.
When you replaced your base/hub, you would have needed to remove all devices connected to that base/hub - have you done that?
https://kb.arlo.com/000062438/How-do-I-factory-reset-and-re-sync-my-Arlo-camera
