In reply to my earlier post, for some reason the solution is to switch batteries. Even though they are still full batteries the existing ones seem to keep it thinking that it has to look for its original base station. Once you switch to a new set of batteries it seems to also switch to the blue light and let you sync properly.
I have no explanation for this.
Its prob not the batteries, but more likely your resetting the camera by the battery removal.
Or they were weak which can prevent syncing
Not sure this will help but the only choice you have is to use the reset button on the back (next to the power button) until the LEDs flash amber. Wait until you get the green power and Internet LEDs and then try again to use the Add Device button on the Cameras tab.
