  • 2 Replies
  • 3776 Views
pherb
I recently purchased the 4-pack Arlo. One camera will synch; no others. I have tried all cameras and they seem to be working fine. my network has 1.5 mbs upload. Any suggestions?
The Sync has nothing to do with upload speed - its all about the WiFi connection with the base station, which has nothing to do with your router and/or modem. I'd 1) open the cameras' battery door for a few seconds and close them. Now, try syncing in close proximity with the base. If that doesn't work, try a base station reset and then try again. Once paired, check the firmware version on both the cameras and base and make sure the auto update feature is enabled.
willied63
