  • 1 Reply
  • 3558 Views
blkcloud
Hi, here is the scenerio..
I install a  Arlo Smart Security - 3 HD system at my business and both my partner and I download the app to view the cameras.. then I install one at my home.. I use the same app for both home and work.. .. can my partner see the camera view at my home also?  thanks!
The APP doesn't make the difference.
But, If you and your partner as using the same account ( email / password ) AND you set up you home cameras under the same accout then YES.
He would see all the cameras on the account too.
If you want to separate the two, you would have to create a new account for your home cameras with a new eamil and password.
