battery life and costs
I have had the arlo for about a week now. The three units came with batteries which only showed half life left when installed. Now one camera is dead. The batteries are under 3 volts each. The other two cameras don't have much life left either. Cost of new batteries at Battery + store are $6.99 per battery!!!
What is the normal life of these batteries. At 4 batteries per camera I will go broke soon. Spending $83.88 for batteries is crazy!
So how long should they last and shouldn't they have had a full charge when purchased?
If your using the OEM batteries that came with the units... a normal life is aprox 4+ months. Most of my cameras do this on best video quality and 2 with very little use made it to 7 months. BTW, online the last sets I bought were about $1.50 each
Brand new they should test at 3.2v
Also , Spec usage is 4 mins per day in case you are recording / viewing with heavy usage.
If you think the cells are bad, contact Netgear.
thought they should last more than a week....
How do I contact them? Can't find a number anywhere...
We just went to the local Batteries + store...thought that was just too much to spend.
How do I see how much usage the camera is doing per day?
Top of page "support" then " contact support"
Thanks...right in front of me but still hard to find..
Sent a message to them so now it's just wait to see if they answer...
I have the 3 camera system and we received this as a gift from a family member. I have already replaced the batteries that came with the camera system with a four pack that Fry's has I put them in around the 30th of January and now there are dead and today is the 23rd of Febuary 2016. Netgear says that batteries should last up to 6 months but this claim is false. I will no longer buy batteries for this system again. I'm VERY UNHAPPY with this product.
raypreble wrote:I have the 3 camera system and we received this as a gift from a family member. I have already replaced the batteries that came with the camera system with a four pack that Fry's has I put them in around the 30th of January and now there are dead and today is the 23rd of Febuary 2016. Netgear says that batteries should last up to 6 months but this claim is false. I will no longer buy batteries for this system again. I'm VERY UNHAPPY with this product.
How many video clips did you record in those 24 days? What's the total duration per camera?
The official use-case scenario is a battery life expectancy of 4-6 months with a 4-minute video clip per day per camera.
If you exceeded that, you're bound to have fewer days of battery life. If you didn't exceed that, then something could be wrong with your cameras.
I've had my system since the middle of December and one of my five cameras' battery gauge has gone done one bar a couple days ago. Though, I'm below the 4-minute clip time per day.
I just set up the camera last night and this afternoon one of batters reads 85%. The system was purchased in order to monitor indoor and out. I've been reading the posts concerning short battery life. If this is the case, the system is a waste of money. On the other hand some posts say the batteries can last up to 4-6 months. Can someone please explain how the system can be set to obtain maximum battery life. The literature accompanying the system is lacking and I am confused. I was so excited after buying the system and getting it set up but, very disappointed when I started reading about the battery issue. Hope you can help.
First batteries generally get used quickly due to aiming and experimentation. Spec life is based on 5minutes' recording and live viewing. Low usage can get more than 6 months, heavy usage can deplete in a week or less. WiFi signal strength and/or interference can also be the issue.
Thank u for the quick response. Still not clear on what 'heavy use' implies. Here's an example of how I want to use the cameras: Outside in backyard monitoring gate and back door entrances as well as yard. Say for example, one or more racoons enter the yard and wonder around for an hour or so. As the night progresses other small animals enter and exit the area. Would this be considered 'heavy use' and what effect would this be on the batteries? This will give me a better idea whether or not I have the right equipment. Thank u.
Spec use is ~5 minutes recording and/or live viewing per day. Watching racoons all night will kill the batteries quickly so, yes, your usage implies heavy usage. A wired system would be a better choice if you really want to do this (I'd rather trap and move them). This system isn't for watching wildlife - it's for monitoring doors, sidewalks, etc.
Thanks for the clarification. It appears this system does not meet my needs. FYI, my intent is not to record wildlife all night. As my inquiry stated the purpose for the camera is to monitor the backyard entry gate, back door into the house as well as any suspicious activity that may occur in the yard. It just so happens that we live in an area where wildlife come out at night. That includes not only racoons, but other wildlife as well as domestic cats, etc.
Jmarkj, thank you for the informative response. It sounds like I would have the same problems as you have incurred with your system. As we only have a 15 day window to return the system we must act quickly. I wish Arlo had been more clear when promoting this product. Would have saved us a lot of trouble.
Based on what you're saying, Arlo may still be a fit for your needs. It's all about positioning the cameras. Many folks try to get the whole scene rather than to focus in on the actual area of concern. That is, they'll go for the whole front or back yard rather than just the gate or door. That causes various issues including false triggers and battery depletion. Positioning and aiming the cameras properly can make a world of difference.
We just got our back in the box and will be returning to Best Buy this afternoon. They only have a 15 day return policy on electronics. Looks like we will need to go with a wired system, I guess. We'll need to locate a technician who can run the wiring and set it up. Thanks for the feedback and good luck.
