I have 2 cameras that were working fine. I moved them. One is working fine. The other tried to re-synch but jjust kept failing. I got new batteries. All it will do is turn blue when the batteries are put in. It won't even
blink blue and then fail to amber blink like before. I had removed it and tried to re-add like people have said to do but that didn't work. I also turned the base off and on. The other camera is a couple 100 feet away from the base and is working perfectly. I can't see why this other camera would stop working. It was a little damp but now has sat inside for a couple days and still won't synch. I have tried a zillion times and am frustrated. This system is only a few months old. I don't want to return the whole system as the one camera is fine. Can I get a new camera sent? thanks Karen
thanks still not working.
Karen9858,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
