Hi
I have recently installed a 3 camera system. Can you advise if the cameras use battery power when in standby mode. The cameras are availble for streaming video if I acess any one of the three. Also once activated to monitor mode how long can one expect a new set of batteries to last assuming an activation time of 8 hours with 5 x 2 minuite recordings on middle power consumption / quality setting. Also can montion detection on one camera activate another to record?
thank you
Shane
Australia
First, in standby mode, the cameras almost use no power.
i would guess about 2-3 months. as spec use is 4 mins per day and your going double.
The only time the camera is using power is in motion detect ( little ) and recording/live view ( the most )... But in normal spec usage ( 4 mins per day / optimized video settings ) batteries should last 4 months or more. ( I use my cams about spec in best video mode and avg very close to 4 months. Other cams I use very little and the batteries lasted almost 7 months )
yes... very common usage in large open areas or where 2 cameras cover a section.
You have cam A and B,
make #1 rule if motion on 1, record on 1
make #2 rule if motion on 1, record on 2
Put them checked on and activate them in a new Mode
