arlo will not pickup cats
will not pick up my cats in there cat enclosure
Sure it will... Have done it many times watching my elderly cat.
but remember, a cat is smaller than a person and it helps to bring the camera down to their level.
yep, arlo is definitely cat friendly
https://arlo.netgear.com/hmsweb/users/library/share/link/2BCB456C72C3FDC6_201706
then why mine not do the same see the cat on camera but not record on libary
As mentioned... cats are much smaller than people and put out a lower IR signature... IR is how the camera detects motion.
You'll have to bring the camera down and closer to the action.
Try and just place a camera on one of the cats's platform as a temp location till you find one that works... Also there is a sense level adjustment too.
( I run mine about 92% for the cat )
