arlo, percentages set on cameras equal to footage distance?
does anybody have an idea about percentages set on cameras equal to footage distance
Not sure what you're asking.
If you mean % ofsense levels vs distanance to pick up ... not really...
There are always different variables in each camera placement... I have had to change settings when swapping two cameras tho same detect distance.
The PIR on the arlo maxs at about 20ft and most of my outdoor cams sit at about 88% , while indoors, with less interence from external IR , they sit at 92%
( believe the default sits at 80 )
