  • 9 Replies
  • 5179 Views
lildaddy75249
The Ir iluminators do have a limited range...
With the Arlos , the light is more center weighted and outdoors it will appear not to cover far...but it will cover just about to the PIR detect range for people about 20ft  ( but not really bright )
Indoors, like the garage, the IR will reflect off the walls ,etc and make the illuminators appear brighter.
With the PROs, the illuminators tend to be better placed, giving a more average placed light....
9 REPLIES 9
Looks like the video has been deleted.
Is Night Vision enabled in Settings, My Devices, your camera? If it is, what is the distance you're trying to cover? The built-in IR illuminators aren't terribly strong because of the battery requirements.
lildaddy75249
Just a 2 car garage. I put the arlo pro in the garage and it works fine way brighter
lildaddy75249
Night vision is enabled
lildaddy75249
Ill try to post a pic
lildaddy75249
Thx
lildaddy75249
To dark even if i adjust the brightness bar still no change
Two things:
1) Make sure Night Vision is enabled. Toggle off and back on. Can you see the dull red glow from the camera when motion is detected?
2) Open a case with support. Might be a bad camera. https://www.arlo.com/en-us/support/contact.aspx
