arlo base station is offline
Hi guy,
Some internet connection issues may be found in China.My base station appeared offline yesterday while other internet services were ok.
I tried to reset my internet connection but the result was same.
DNS pollution?While the alro service was based on AWS.
Is there any localized solution in China?
edwin1986,
Are you still seeing this behavior? What color is the internet LED on your base station?
Consider rebooting your base station (using the on-off button) and try again.
