  • 1 Reply
  • 2913 Views
tooner_58576
i was going to buy a add on camera and found that the 2 camera kit w base station is cheaper  If i buy a 2 camera kit will these link up to my other base station or just the base station that it comes with it?
Arlo and Arlo Pro cameras will work and sync to either base unit...
On the Basic ( free ) level , you can use 5 cameras max, there is no limit on the number of bases.
( additional bases are the only way to really expand your coverage area if needed )
