One of my ARLO cameras is bricked
Hello, Batteries died on one of my cameras. I replaced with fresh new ones, orange and blue lights flashed and then nothing. cant synch, get get them to light up again. please advise how to reset or how to fix. Thanks
Hello @douginla,
I've just sent you a private message requesting for information regarding your Arlo Security System.
I'm looking forward to working with you on resolving this.
KristynM
Arlo Support Team
douginla wrote:Hello, Batteries died on one of my cameras. I replaced with fresh new ones, orange and blue lights flashed and then nothing. cant synch, get get them to light up again. please advise how to reset or how to fix. Thanks
Hello douginla,
I have created a case for you in our Support ticketing system, and an Arlo expert will be reaching out to you in short order.
DanielT
Netgear Arlo Customer Support
I am having the same issue. Fresh batteries I get one click one blue light and then nothing. When depressing the camera sync button no lights will light at all. The only time I can get one blue light is when opening and shutting battery door and again I get one click one blue light then the camera reacts to nothing. All other syncing and trouble shooting methods have been applied with no results. Thaks for your assistance.
CJMG,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link. If you have any additional questions/concerns feel free to private message me. I would be happy to help.
All cameras bricked were attached to the same router. Four cameras attached to other router are functioning nominally. Clearly and induced issue related to the specific router.
Argomutt,
It's possible the issue could be depleted batteries. Consider installing a fresh set of batteries and try again.
