  • 6 Replies
  • 4241 Views
banneheke
after changing battery camera is still off line. What should I do.
banneheke
Battery was fine thanks. It is working now. I had to re boot.
6 REPLIES 6
First make sure the batteries are in correctly... There is a label just inside hats show +/-
When first closed , you should see the led show blue for a second
Try and resync again ... Only press the base button quickly, don't hold.
If still NG, go to settings, pick the camera and use Remove Device...then bring back as new
banneheke
I did all that. Still not working
Try power cycling the base.
steve_t
Master Master
Did the blue LED blink? Is it possible that your 'new' batteries are faulty?
banneheke
steve_t
Master Master
So it is working now after a reboot? That's good
