each motion detection records 10 seconds, can i increase that time interval?
The time can be increased up to 2 mins...
You have to go into Modes, then pick edit ,then pick camera and edit again, then edit the record by clicking edit pencil and adjust time.
I do recommend not using the default modes but "copy" them into a new custom mode and do editing there.
Thank you for your input. I followed your instruction, but the new length was not taken. why? I don't see "save" button.
I got it. the "save" button is when back to "Edit Rule". thanks so much
I followed all your instructions but when i go to mode, then armed, then edit, there is nothing about extending time....all i see is sensitivity detection...
Next section down - "Then Do The Following". Edit the Recording Video section. If that's missing, you either need to make your own mode with appropriate rules for your cameras (this is the recommended method) or reset your base, remove all devices in Settings, My Devices and start fresh using the Add Device button on the Devices tab. This will rebuild the default modes.
