adding base station
my reception isnt great amonst my 7 cameras all working off one base station, need to add an additional base station.
does the additional base station automatically pick up the nearest camera, or do I have to resync the cameras with the base station I want them to work off of?
jkbg4835 wrote:my reception isnt great amonst my 7 cameras all working off one base station, need to add an additional base station.
Cameras have to be sync'ed to the base station wanted to work off of, they can only be sync'ed to one base at a time...
you have to remove them from the previous base ( SETTINGS-System Settings -CAMERA ORDER, then click the circled X at the camera line on right side )
BTW, you either have to run 2 separate accounts or pick the Elite service which allows up to 3 bases. ( premier allows 10 cams / 1 base )
As a PS... you can run ethernet cable for a good distance ( 100m ) so it may be worth it if you can centrally locate the base
