  • 4369 Views
Boone0811
Wireless log on I live in the country and have AT&T wireless hot spot. How can I hook the next gear to this unit
Boone0811
Boone0811
Boone0811
I have an AT&T hotspot can I hook this to the next gear & how?
What model hotspot and are there ports?
You should be able to use a hot spot IF your service is fast enough ( 1 meg transfer the minimum ) AND the hot spot device has an ethernet port.
The base must be connected to an ethernet port via the cable and have internet access.
