This camera is a POS. Never works properly. Eats batteries like crazy.
Constantly records when there is no movement seen in the replay. Also does not record movement when there is something to record. I recently had something moved by somebody in front of house and nothing on the recordings,. People coming and leaving my front door are not recorded. Have tried everything including changing the motion sensor but no matter what the setting I get same problem.
What a waste of money. Cost me over 10% of my SSA. No more Netgear products for this old lady.
Wish I had never bought this system. Ready to s**tcan it and get something else.
Not sure what they ask for above for model and all I know it is wireless and sells for $199.
I have been almost an hour trying to get this to post. What an anoying website.
Also, post screenshots of your cameras' views. If they can be repositioned properly things may get better fast.
Thanks but most of what you recommend is not possible.
I have fast 15MBPS internet speed so that is not the problem
As for a few cameras this is not feasible. I already have one that goes through these very expensive batteries. Also there is nowhere else a camera can be attached outside. The one I have covers more than the area I am interested in protecting as it is a very small courtyard and the camera covers my area as well as the next door area.
Outside lights are always on as this is provided by the community on each residents garage to light up the pathway to your front door.
The camera works only when it wants to and I have at times captured people coming or going. It is very erratic.
I have no idea what you mean by iffft.
I will just have to wait until I can afford a different security system or a family member buys one for me.
Thank you for your response.
It is not the position of the camera. It is positioned so that it shows my complete front area and even over into the neighbors. Where it is positioned is the only place there is any wood to attach it.
Again, a screenshot would help.
As for positioning, wood isn't the only possible mounting material, just one of the easiest to work with. Also, it would seem that you're covering too much area for motion to be detected efficiently. The screenshot would help here.
