Wireless Arlo and R7000 router.
I've had my new Arlo Q camera working great with my R7000 router for more than a week so I decided to add to my system by purchasing a single wireless camera.
I can't get the wireless Arlo to connect with the router after I go through the steps;
1) Hold down the WPS button on the router until it flashes.
2) Press the sync button on the top of the camera.
The blue light flashes on the camera (slowly and then faster) but then goes out. I don't get the green light showing it's working.
Am I missing a step?
The R7000 is needed without a base for the wireless cameras since it builds a dedicated WiFi connection with the cameras. Q needs only the normal WiFi that all your other devices use.
At this point, I'd first make sure your router firmware is the latest and possibly factory reset the router. If that doesn't work, create a trouble ticket with the R7000 folks to get help with it. The cameras, assuming both do the same thing with slow blinking blue LED followed by rapid blinking and then all are off, are giving you the right indication so I would suspect the router first.
