We recently purchased a couple Arlo wire-free cameras and I'm having trouble deciding if where we chose to place them is the best option. I'm attaching two photos here and would love your advice. One camera is for our back patio. One camera is for a side door near our garage (sorry, not sure why it's showing up sideways). Based on the photos, where would you suggest placing the camera for the optimal coverage? I have noticed that where I placed the camera by our garage...it doesn't give the Arlo a lot of time to notice movement. It's kind of narrow up to that black door and currently I have the camera placed above the door. Any suggestions are welcome. Thank you.
Cannot see the pictures yet...
As a rule of thumb, the Arlo Wire-Free cameras perform better if the subject moves accross the field of view, R-L L-R. If the Subject moves towards the camera, I suggest a little trial and error testing before you install the unit. we will know better when we see the attached pictures
Let me know if the photos aren't showing up still. When I pull the conversation up it shows me the pictures.
Any camera (or other device such as motion-activated lighting) that uses PIR detectors will always be more sensitive to motion across the FOV compared to directly at it. The detector uses a differential scheme which means that the subject has to be seen as changing - directly at the sensor has a much smaller differential than moving across the FOV. The above mentioned lights' directions will tell you the same thing.
https://en.wikipedia.org/wiki/Passive_infrared_sensor#Differential_detection
It takes time for images to be approved.
The patio has many more possibilities than the garage door. However, you don't indicate where motion would likely come from. You want motion across the FOV which could be detected from any of the walls shown. Tell us more about the scenario.
The garage door has issues - I'd mount it on a side wall, perhaps rotated a bit rather than straight down. The corner by the door may work as long as you resist pointing it out the opening and try to keep just the door and sidewalk in view. Alternatively, mounting it close to the actual entrance opening, getting the door and sidewalk, may be as effective since the motion would trigger the camera and you'd get the subject at least walking away from the door.
In either caase experimentation is needed for best results. Just try to minimize the view - too much scene hurts best detection.
Here is a better picture of the side door. (Hopefully picture won't take too long to be approved you can see the scenerio) I'm thinking that maybe putting it under the eave above the garage door may be better so that the motion toward the door will be detected in the left to right direction? As you can see in the photo, it's currently mounted above the door.
Got the image now. Exactly what are you trying to monitor - just the entry door or the garage door, too? I might be inclined to place it next to one of the downspouts which would not only help hide it but would provide side-to-side motion detection.
