Looking to mount a couple of Arlo cams with the outdoor adjustable mount (VMA1000) on brick walls. Anyone know what size drill bits I should use for the studs and also how deep?
Thanks!
Ltwo wrote:Looking to mount a couple of Arlo cams with the outdoor adjustable mount (VMA1000) on brick walls. Anyone know what size drill bits I should use for the studs and also how deep?
Thanks!
Since your using them on brick... the size of the drill is based on the outside diameter of the plug that's going into the wall hole. ( plug is what the screw goes into )
As a normal rule the size of a drill for screws is the diameter of the shaft ( of the screw ) not counting the threads
BUT before you go drilling permanent holes, I would suggest using a temp mounting to make sure the cameras are in a good working location.
Mount with 3M double stick molding tape, etc to hold in place
What kind of answer is that? You provided the screws and such... don't you know what drill bit we should use?
One in every crowd........
Paul
