  • 4 Replies
  • 3481 Views
Retired_Member
Not applicable
Could someone assist? I'm trying to buy the camera system but are confused in the tech difference between the two and would like to make an informed choice
Same but one set has two cameras... Original Arlo HD camera and 3000 base
Arlo Wire-Free Security System with 2 HD Cameras (VMS3230) ... Just connect the base station to your WiFi router, sync your cameras, fire up the free Arlo app, and you’re done in minutes. Make sure to upgrade your service plan and add more cameras to make the most out of your system.
Arlo Wire-Free Security System with 1 HD Camera (VMS3130) With an Arlo system, you'll have everything you need to get started. Just connect the base station to your WiFi router, sync your cameras, fire up the free Arlo app, and you're done in minutes.
Retired_Member
Not applicable
Thank you Tom,
will I be able to add more cameras to the system at any point or will they only support either 1 or 2 cameras?
Retired_Member
Not applicable
Will I be able to add more cameras at any point or do the stations only support either 1 or 2 cameras?
On the basic plan ( free ) you can add up to 5 cameras total
