what does adding USB memory to the base station do?
If you have a newer base ( not a 3000 model) the mem card will hold the same vids that go to the 7 day cloud except they do not get erased. ( till card is full or you choose it to overwrite the old when 80%full )
you can pull the mem stick and view in most computers.
If you have a base that accepts it, the usb memory is a backup to the cloud... any triggered event goes to both there and cloud.
Nice if you have the basic level of 7 days storage....cause a 64gb speed stick will retain a couple months worth
That's the answer I needed, thanks
