  • 4 Replies
  • 3231 Views
Pandaman
what does adding USB memory to the base station do?
If you have a newer base ( not a 3000 model) the mem card will hold the same vids that go to the 7 day cloud except they do not get erased. ( till card is full or you choose it to overwrite the old when 80%full )
you can pull the mem stick and view in most computers.
https://kb.arlo.com/1146857/How-do-I-set-up-local-storage-backups-on-a-USB-device-using-my-Arlo-base...
If you have a base that accepts it, the usb memory is a backup to the cloud... any triggered event goes to both there and cloud.
Nice if you have the basic level of 7 days storage....cause a 64gb speed stick will retain a couple months worth
Pandaman
Thank you Guru, So I did install a 64gb, but does this mean that if I still only see 7 days on the APP, there is actually more collecting on the USB than I see on the APP?
Pandaman
That's the answer I needed, thanks
