What cameras are compatible with VMS3230? Will Pro/Pro 2 work with this Base Station?
I have the vms3230 base with 2 wire free cameras. I want to switch to wireless cameras that use a power source.
What cameras are compatible with this base?
Will the Pro or Pro2 work with this bass?
Will the Pro or Pro2 work with this base?
Both the Pro and the Pro2 will work with your base. The Ultra isn't compatible, so you'd need to get a new base for that.
If your cameras are outside, you will need outdoor power adapters (the VMA4900 in the case of the Pro and Pro-2). These need to be purchased separately.
If the cameras are inside, you still might need to purchase additional indoor power adapters (VMA4800 for the Pro and Pro-2). The multi-camera packages won't have one adapter per camera.
These cameras can be powered with no batteries inside, but Arlo does suggest keeping the battery in as well.
