  • 4 Replies
  • 2965 Views
Ozz666
Installed my system over the weekend, no issues setting up the modes and rules using the web site. But now when I log into the web site to tweak some settings there are things not right.
  1. When editing a rule and trying to change the motion sensitivity it displays {{getMotionSensitivity()}} to the right of the slider where number should be. Moving the slider changes {{getMotionSensitivity()}} to NaN. These look like javascript issues to me.
  2. When editing a rule the section "Then do the following" is empty.
In both instances the Android app works fine in displaying the motion sensitivity and the actions to take.
Anyone else having similar issues with the website ? I am using Chrome on Win8.1 and have also tried IE11.
TIA
appears fine in working order here... have you tried Fire Fox ?? ( their updates on a reg basis seems to keep it working right for me )
Ozz666
I have an old version of FF that I need to keep at that version for something related to work, but I tried in FF on my linux system and the result is the same. Also tried the latest version of FF on a winXP virtual machine with the same results.
Ozz666,
Do you have cookies enabled on these browsers?
Ozz666
Yes I have cookies enabled. I also cleared all the cookies and tried again with the same results.
