Wireless hub keeps going offline? How is this marketed as a security camera?
  • 1 Reply
  • 2610 Views
Horizonlawn
I'm having serious issues with my whole system going offline. If I reset the hub it's fine for a day or so. Problem is I purchased this for security monitoring and resetting the hub all the time is unacceptable. Mostly because I'm not there to reset the hub. If I was there I suppose I wouldn't need cameras anyways. So is there a solution to this or is this the quality of software this company builds? The problem is not with my network as I have a home automation system working perfectly.
Couple of questions. When the system is offline, what are the LEDs doing on the base? There should be 3 lit, all green. Of particular importance, it's the Internet one that should be green. Second, does your router show an IP address for the base when it's offline?
