I have been recieving my notification email but the website seems to be down I can not log in to view recordings. The email notifications do have the still picture of the start of the recording so I can tell the cameras did 'see' something.
AFAIK, the site has been up the whole time. I'm not having any problems. There was a recent issue with Cox Internet service which folks were quick to blame Arlo for. Since this system is cloud-based, any break in the connection across the WWW can cause an issue, starting with your network and ending at the Amazon AWS servers.
Try a different device/browser and/or a mobile device on both WiFi and cell service.
JPI80918,
What are you experiencing that is preventing you from logging in? Give us details about what you are seeing when you navigate to arlo.netgear.com and attempt to log in.
I enter username/password @ the login screen then I see the Hummingbird logo with the wing cycling through each piece of the wifi symbol.
1) Running Chrome Version 65.0.3325.181 (Official Build) (64-bit) on Windows 10.
a) Website is added to trusted
b) Website is allowed popups
c) Flash player is up-to-date
2) Comcast WIRED LAN connection to the internet
a) no other website logins have an issue.
JPI80918,
Are you running any virus/malware protection software that could be blocking the Arlo website?
Try a different browser to see if you experiencing the same behavior.
