even www.arlo.netgear.com is not available - it just came back online. I was going to buy more but this is the 2nd time in less than 2 weeks that netgear was down. I won't be making any new purchases until I see how this issue pans out
any chance the problem is at your end. In past more than two weeks I've had no cases I couldnt get in, and I go in every hour or so.
Having retired from IT myself, I know only too well what you mean. If they were down it couldnt have been too long because I have a recording made every hour or two.
Just remember that access from work is frequently problematic due to ports being needed. If you were able to access the site previously, then that's not the issue but if just the first time, it's possible that the network is blocking access. A better test would then be via the app trying both WiFi as well as cell service.
