Arlo Base Station Camera Sync LED stays constant amber. Other two are constant green.
When I push the sync button on the base it will temporarily blink green and the camera I am trying to sync will blink blue but then when finished the base goes back to constant orange and it says offline when I look at my devices.
whichof the three lights on the baseg oes backt o orange?
The camera sync led goes back to orange. The first two left to right is green, power and internet. The third one is constant amber. I am going to try to delete my base device tonight and add it back. I think this started happening when I finally selected to update the other day after constantly selecting to do it later. Wish I would have kept putting it off.
Solid amber for the Camera LED means the base needs to be claimed. Use the Add Device button to add the base. You may need to remove all devices from Settings, My Devices and start fresh using the Add Devcie button.
