I was tying to delete stored footage off my app and accidently deleted the cameras from my devices...They should make that harder than just two clicks... anyway, im out of town and want to know if there is a way to reconnect my deleted cameras. My base station is still connected.
Only with the Ultra cameras which use only the app to sync. For all the others, you have to be able to push the sync buttons.
Might be a silly question but how did you get from deleting videos in the library to removing the cameras from Settings, My Devices? Much more than 2 clicks.
maybe try to do soft reset on the base from the app, if nothing works, then you have to be at the house, add and resync the camera.
It takes a minimum of 3 clicks from first logged in, including the confirmation that you want to remove the camera.
