Warning Triangle next to base station settings
  • 4 Replies
  • 4159 Views
nickgtr35
i have a red warning triangle in settings next to base station settings, anyone know what this is? it appeared after i try to manually update firmware. but firmware update does not work
Showguy
Virtuoso
Virtuoso
The triangle indicates there is a firmware update available.
Showguy
Virtuoso
Virtuoso
nickgtr35
Thanks problem is that even with auto renew on the firmware does not update
Moonbeamljm
I have updated firmware and it still shows triangle
Is this on a camera or the base?  You can try power cycling the base and opening and closing the battery door to see if that helps.  Beyond that you just have to wait for the firmware to update by itself (should happen overnight).
