  • 1 Reply
  • 1951 Views
Sms61
Hello,
I am trying to connect a WiFi extender (netgear AC1200) to my Arlo system model #VMS3430 and base station # is VMB3000 so a further away camera will not have a sketchy connection. I thought I set the extender up correctly, on my iPhone under settings i try to connect to the extender and don’t have the correct password. I choose same password in set up. I have reset my Arlo acct password, But I did read on a previous password question, that wouldn’t change the router base station password and I can’t remember and apparently did not write it down where it should have been🙄
Thanks in advance for your help!
Only support will be able to help you if your forgot your password
