Recently having video playback issues via the app...note that it's only the app as the web portal has no issues. Clearing the cache and reinstalling the app doesn't help. Speedtest, via WiFi, shows Download - 360 Mbps & Upload - 12 Mbps.
When playing videos on the app, the playback pauses constantly and jumps 2-3 seconds at a time (YouTube video link at bottom), which varies by camera and whether you're trying to play it in Dashboard, Devices or Feed. This only affects video playback and not local live streaming. Below I've listed which scenarios/cameras are affected (yes or no). Note that these results are the same regardless of if I'm on the cell network or via WiFi.
DASHBOARD
- Wired Doorbell - YES
- Ultra 2 Camera (2) - YES
- Pro 3 Camera (2) - NO
FEED
- All Cameras & Doorbell - YES
DEVICES
https://www.youtube.com/shorts/YuS7ZaKxmdk
I just tried this on both the web and Android app (6.2.2). I did see slight "stuttering" on occasion but overall the playback was pretty smooth.
Checked again this morning and have the same pause/stutter on the app that it had prior to 6.2.2
Web portal is smooth as ever but it's odd that all the videos on the web portal yesterday, from midnight to 4PM, have that more slight rapid stutter but as long as the web portal is back to normal then I won't worry about it...my concern is that when I first checked 6.2.2, after the update, playback was smooth but now it's back to the pre 6.2.2 pause/stutter.
I just checked videos from a variety of cameras (Q, E2 indoors, Pro 3 floodlight, 1st gen wireless doorbell) and all showed a smooth playback with an occasional "missing frame" (my description) that caused a slight hiccup in the playback. I suppose the issue could be sporadic but I haven't seen that.
Here's a YouTube link to a video I screen recorded this morning...
https://youtube.com/shorts/U7DSQPX7dMg?feature=share
@BrookeN
The following, below in underlined italics, is what I started this discussion with on 05/02. It all holds true again, after everything had worked flawlessly for a couple of days after the 6.2.2 update...
When playing videos on the app, the playback pauses constantly and jumps 2-3 seconds at a time, which varies by camera and whether you're trying to play it in Dashboard, Devices or Feed. This only affects video playback and not local live streaming or local recordings. Below I've listed which scenarios/cameras are affected (yes or no). Note that these results are the same regardless of if I'm on the cell network or via WiFi.
DASHBOARD
FEED
DEVICES
@KachinaShadow wrote:
Are you still on 6.2.2?
I show that I am now on 6.2.4...release date 07/04/25
I'm still on 6.2.2...
I am wondering if it is a signal issue more then the behavior you were seeing previously.
@BrookeN
You mean the signal from the camera to the base?
I wouldn't think so since the behavior is virtually identical in every respect to the pre-6.2.2 fix and, as you saw in the breakdown of cameras/modes (in message 106 & message 1) the Pro 3's which are the farthest, by double from the base, have no issues in Dashboard or Devices and none of the cameras have an issue live streaming.
I'm at a loss since, with 6.2.2 on the 11th, everything was resolved for at least 2-3 maybe 4 days (I didn't pay much attention since the issue was solved) but then on the 15th I discovered the issue had returned. This may be a shot in the dark, since I don't know what day I was updated to 6.2.4_28897 (which oddly enough has a release date of 07/04/25), but could that have anything to do with it?
Is there any way to revert back to 6.2.2 and see what that does?
Paul
I see a July 13 date on my 6.2.4 app (it updated yesterday). I wonder if it would help if you reinstalled the app to see what happens.
The only way to revert app versions is to locate the APK file on the internet. WHile I've done this in the past with no known issues, it's always a risk since you don't know whether something has been inserted into the download.
Just reinstalled the app which still shows the same 6.2.4 update with the July 4th release date...didn't solve the issue!
@BrookeN why would @jguerdat 6.2.4 update show a July 13th release date while mine shows a July 4th release date?
Also I find it unusual that my 6.2.4 update shows an earlier release date of July 4th when my earlier 6.2.2 update showed a release date of July 8th 🤔
Cloud video playback performance is better since the start of the 6.2.2 update, though still not 100%.
You still on 6.2.2 or now on 6.2.4?
I've had each update since
6.2.2, currently on 6.2.7.
I'm also on 6.2.7 but still have the pre-6.2.2 issue with the live streaming. It was good for a few days after 6.2.2 rolled out but then it went back to the same problem, which continues to happen with 6.2.7.
Hi!
Im facing an issue with playback the feed video on my app. I can see the videos in my app, when press the playback only sounds plays, but the screen is blank. Tried to uninstall and updste , issue remains. Thank you for your help!
@Adlermiles555 are you still seeing this same behavior?
I see we're now on 6.3.4 but I still have the same pre 6.2.2 issue
@clove wrote:0
Something I'm missing here 🤔
Those are spam bots you can just disregard those messages.
Just an FYI for anyone still seeing choppy playback issues, here's something I found when trying various scenarios with playing back videos...
"Today I used "Feed" to try some things, since "Feed" is where every camera has the issue...I found that if I select any video from any camera and play it, that video then has the (choppy) playback issue and if I swipe to the next one or two videos, they also have the issue but if I continue to swipe on to other videos, they play smooth with no issue. Even if I swipe back to those first two or three videos that had the issue, they now play smoothly with no issue (note that sometimes just allowing the first video to play all the way through and then re-watching, it plays fine along with any videos before and after that you swipe to)
You'll notice that I put swipe in bold and underlined it...this is because swipe may be one of the keys to this whole thing (that and or re-watching the video after allowing it to play all the way through). But, if you go out of the "play" screen and then back to the list of videos and select another video, even if you choose the same video that previously had the issue and then got well, the whole scenario starts over again."
Note that tomorrow morning I have a call with Arlo L3 Support to hopefully get this issue figured out.
@KachinaShadow were you able to resolve the behavior you are seeing with L3?
@BrookeN
Sorry for the delay, just got back from vacation yesterday.
To answer your question, L3 Jeffrey was able to look at the video clip and see that there is an issue (there still is), had me try a few things and said he was sending the problem on to, I believe, engineering and would let me know if there was any progress but that was the last I heard of it.
Maybe you can find out what's going on
Thank you for the update. I hope you had a great vacation! I will reach out to Jeff and see if there are any updates.
