Vehicles 100ft away
Is there anyway possible my Arlo Smart Wireless Camera is recording vehicles passing parallel 100ft away?
Yes, it's possible. Tho the view wouldn't be greatest at the distance.
The Arlo cams are triggered by IR or the reflection of same...cars are a big reflector ( windshields, etc ) and many times it will give triggers to record.
Most of the time to many false triggers are due to trying to cover an overly large area... I find the PIR device ( reads the IR ) works best on people at about a max of 20ft... If this is the problem your having , try and lower the aim of the camera to avoid the false triggers ( roadway )
