  • 1 Reply
  • 2987 Views
BJK4
Hi
I cannot get my base station to sync to my router
The power light is amber then the internet light will go from off to green for a short while. Then the power light goes green and the internet light switches off completely(the router light continues to flashes green on the router)
I have also tried the base station in various router plugins..same result
BTW i've tried numerous reboots etc
Not Happy!
Once the base has booted (about 2 minutes), the power and Internet LEDs should be green.  If power is amber at any point after that, you have a base or power supply issue.  The Internet LED shows off if no connection to the router (bad port or cable), amber if the base got an IP address but no connection to the servers (router blocking somethng) or green if all is good.  What exactly are you seeing?
