VMC3030 not recognizing the QR code from APP
  • 4 Replies
  • 2823 Views
LINISIS
Good Day,
VMC3030 not recognizing the QR code from APP. Tried moving the camera, nothing workout.
THanks
The VMC3030 can't connect to your home wifi, and the on-boarding process doesn't including scanning a QR code.
Either you entered the wrong camera model here, or you specified the wrong device when you tried to add it.
Starting with confusion on the camera model - the VMC3030 is the original Arlo WireFree HD camera.  Unlike other Arlo cameras, it uses 4 CR123 batteries.
Moving on to "add device" - When adding a VMC3030, you specify "Cameras", then "Other".  That will show you a "legacy" screen.  Then choose "Arlo".
LINISIS
Hey,
Thanks for your reply. Model name is correct and its using 4 - 123 Batteries .
As you mentioned in App - i have chosen other - then Arlo. But asking to connect base station.
Please help to resolve.
thanks
LINISIS
Please let me know which model base station or smarthub needed to connect VMC3030 ?
Compatibility info is here:  https://kb.arlo.com/000062284/Arlo-SmartHub-and-Base-Station-Compatibility
Your camera is called the Arlo Wire-Free Camera in this guide.  As you can see, your camera is compatible with all Arlo base stations and SmartHubs.
