VMC 3030 camera goes offline
I have a VNC3030 camera that goes off line often ! I have to constantly open and close battery door to get it back on line ! I have 3 other cameras close by that I don’t have a problem with ! Is there a solution to this ?
That usually points to a connection problem between the base and camera. A quick way to check is to swap cameras around to see if the problem follows the camera or stays with the location.
