- 2
Hello,
After years of working fine, all of a sudden I cannot access the local recordings on the USB drive of my Arlo hub. This happens even when I'm on the same network. The message I get has been quoted often: "There was an error obtaining your library. Arlo team is working on this issue."
Recording locally is activated. The USB device shows ready.
Incidentally, I can also not get the port forwarding status to turn green, even though the IP address and ports are matching. This also used to work before. But since I'm in the local network I should be able to access the library anyway.
I reset the hub, I checked the ethernet connection to the router, I reset my smartphone, I logged out and back in of the app, I removed, checked, and reinserted the USB device. The hub runs 1.26.0.0_1812_12a0681 (no updates available).
Does anybody else have the same issues? How to fix it?
Thank you very much for your instruction to upgrade my interface, however should I continue the upgrade process when Arlo app is warning me that my base station VMB4540r3 is currently not being supported (currently not able to use firmware update)?
And unfortunately, the firmware of my VMB4540r3 is 1.27.0.0_1931_03495c2, and there is no more update to be used.
Thank you both for chiming in. I think I'm in the same situation as Pythony (except my VMB4540 is r2. On the app, I have three options (devices, Library, Mode) and run the same version as Pythony.
I am not yet convinced that this depends on the app version. As I wrote earlier, I tried things out with an old app version (5.7.0_28835, on a different phone) and had the same issues. Namely, the reduced menu without the "Direct Storage Access" switch as shown in the screenshot on 2025-05-02 04:53 PM. That make me think it's related to the hub SW not he app SW. The hub SW has been upgraded very recently.
To add to the confusion: after I formatted the USB drive yesterday, the full interface showed up again on the app (with the "Direct Storage Access" switch and with port forwarding status ok). But after a couple of minutes it changed to the screen without the "Direct Storage Access". In between, all I did was trigger an alarm which created a local recording.
It would really be nice if Arlo could comment and clarify the situation regarding access to local recordings.
For reference, these are my current SW versions:
app 6.0.0_28852
hub 1.27.0.0_1931_03495c2
The Arlo development team is currently investigating reports of this behavior. We will provide an update as soon as we have more information to share with the community.
Hi,
I was informed there has been a backend update. Can you please reboot your app and test this feature again?
Thank you
Great! The option of switching between Cloud and Local storage is back. I am able to check all the recorded video again.
Thank you very much to all the effort of Arlo Team.
That is great news (especially after spending hours trying to debug this problem)!
The local storage configuration is back to normal. Access through the Library menu in the app works also as before. Port forwarding works, too. I didn't have to reboot the hub, nor restart the app.
I am not able to access my local library anymore. I tried rebooting but the hub and my phone but nothing changed despite the fact that they're both on the same WiFi.
A separate thread of you own would be useful. STart it by explaining what phone, OS version, app version, etc. as well as what you've tried as well as what you see. All details are needed.
I have the same problem and I think it started early April. I have the VMB4540r2 connected to four cameras. The cameras are a combination of Pro 3, 4, and 5. I am using a Google Pixel android phone. When I click on “Feed” at the bottom of the app and I switch from cloud (not using) to local I get a spinning circle for a while and then the message that says, “There was an issue loading feed events” I can view the feed from each camera real-time. I took the USB drive out in the images are being recorded, I can see them on my computer.
I have done a lot of troubleshooting. The hub is online. When at home the phone and the hub are all on the same Wi-Fi network. The hub firmware is up to date: 1.26.0.0_1812_12a0681. I have tried restarting several times. I unplugged the hub and plugged it back in. I tried redoing port forwarding and have confirmation that port forwarding is listed as ‘Enabled’. I cannot view stored images with “Feed” even when I am on the same network. I tried restarting the hub several times.
I previously had been able to pull up images by date by using Feed > Local link in the app. Today, for the first time in about a month I was able to see recordings by going to Device > Base station > Storage Settings.
An observation that I cannot explain is sometimes when I try to look at the feed I will lose the connection to the hub. If I wait it will regain the connection.
Will I be able to access recordings like I used to, Feed > Local?
Thanks all,
m
Mine is working now. I did not get the PM if it was to me.
m
Thanks for the update. Is anyone still experiencing this symptom with the local storage?
- 2
