VMB3000 power light is solid green, the internet solid amber
  • 1 Reply
  • 2318 Views
jerbauer
Hi, I'd be grateful for any help you can offer.  I have a VMB3000 base station.  No matter what I try, the power light is solid green, the internet solid amber, and the cameras solid green.
  • I have tried 3 different ethernet cords and tried swiching around the port each is plugged into.  Other wired devices are working fine.
  • I have cycled the power of the modem and the base (tried the base first and also tried the modem first)
  • I have factory reset the base, sticking a pin in the back until the lights flashed.
  • I recevied a brand new modem yesterday but that did not help.  The installer did not have any suggestions either.
I am using AT&T and an Arris wireless modem.  Any ideas?  I really appreciate any help you can offer.
I suggest contacting Arlo support: https://www.arlo.com/en-us/support/contact.aspx
