VMB3000 camera issue
Trying to sync cameras to base-have the 2 green lights on base and 3rd light will flash when I push sync-new batteries in cameras but when I push sync on cameras-nothing! No lights on any sort-any ideas?
When you close the battery door do you get a flash of blue? Are you inserting them properly? Don't push the batteries down, let the door do it for you. Sometimes they stick down and don't make contact.
no flash of any color!
You either have bad batteries or a bad camera. If these are new, swap at the store or open a case with support.
