Edit the recording mode (probably ARMED) and edit the rule for that camera. Next to "Motion is detected" there is either a pencil or a > symbol. Click that. A slide with appear with the sensitivity. It's probably on 80. You'll have to experiment with it to get to the right setting. After you change it, click back. Then scroll down and click SAVE. Don't forget to save or the sensitivity won't change
