  • 2 Replies
  • 4776 Views
Astine2276
Only one of our wireless cameras constantly being triggered for no reason.
steve_t
Master Master
Edit the recording mode (probably ARMED) and edit the rule for that camera. Next to "Motion is detected" there is either a pencil or a > symbol. Click that. A slide with appear with the sensitivity. It's probably on 80. You'll have to experiment with it to get to the right setting. After you change it, click back. Then scroll down and click SAVE. Don't forget to save or the sensitivity won't change
steve_t
Master Master
Astine2276
Thank you for the information. I found it and will test it out.
