VMB3000 Safari won't open
I'm trying to view my camera on my Mac mini, OS X 10.7.5., using Safari. I clink on the link and get an error message, "Safari cannot establish a secure connection with netgear..." I've tried resetting Safari. I've had this issue with other apps. No problem with the camera/reciever itself. I can view it on my MacBook Pro (OS X 10.9.5), just fine.
madlibrarian9,
Do you see this issue when using other browsers, such as Chrome or Firefox?
I just started having this problem as well, seemingly out of the blue. MacBook Pro OS 10.7.5 running Safari. No problem accessing using Firefox.
I have escalated this issue for further investigation. I will post back once I have more information.
Thank you for the feedback,
It's over a year later and you're still not support Safari!
retiredagain,
Are you able to use other browsers such as Chrome or Firefox? Do you see any issues when using these browsers?
When will Arlo start supporting Safari... I dont want Firefox or anyother browers.
If they cant get this together then , I'm just going to take it back - It not worth with if the company can support there users!
It's an Apple/Netgear decision. Apple doesn't support Flash, Netgear still uses it. That may change but you can't count on it. Right now your choice is use a browser that supports Flash or use the app.
I'm still waiting for the move from flash too and not just due to apple... Big hd lcd tv with xbox one ( win 10 similar ) but only see the stills as the box says it needs a new version of flash.
Wouldn't that be great, watching a Q on the big screen 🙂
