How do I delete usernames on the Arlo login page
5 REPLIES 5
Fully log out from the settings page and then use the backspace if still there (you don't say what app/ device )
Sorry, I meant from the pulldown menu on the login page if you have several accounts listed.
I am using a pc Windows 10
That's a function of your browser, not Arlo.
arlouserX,
As mentioned, this is a browser level setting. Depending on which browser you are using, you should be able to manage the saved accounts/password information in the browser settings.
