Upgrading my base station to Arlo Pro base station would allow me to view Arlo Wire-Free camera?
  • 1 Reply
  • 1559 Views
BeRoyalKC
I'm aware that the original Arlo Wire-Free Camera is not compatible with Google Home for some odd reason (works just fine with Alexa). I was curious if just upgrading my base station to the Arlo Pro base station would allow me to view my Arlo Wire-Free Camera through Google Home?  I wasn't sure if it actually had to do with the camera or if it had to do with the original wire-free base station.  The latter seems more likely so I have hope, but wanted to check here.  TIA.
JessicaP
Hi @BeRoyalKC,
Unfortunately even upgrading to the Arlo Pro Base Station, you will not be able to view the Arlo Wire-Free Camera through Google Home as it is just the camera. But you can stream other Arlo cameras to your Google Home.
