Upgrading my base station to Arlo Pro base station would allow me to view Arlo Wire-Free camera?
I'm aware that the original Arlo Wire-Free Camera is not compatible with Google Home for some odd reason (works just fine with Alexa). I was curious if just upgrading my base station to the Arlo Pro base station would allow me to view my Arlo Wire-Free Camera through Google Home? I wasn't sure if it actually had to do with the camera or if it had to do with the original wire-free base station. The latter seems more likely so I have hope, but wanted to check here. TIA.
Hi @BeRoyalKC,
Unfortunately even upgrading to the Arlo Pro Base Station, you will not be able to view the Arlo Wire-Free Camera through Google Home as it is just the camera. But you can stream other Arlo cameras to your Google Home.
