  • 34 Replies
  • 4703 Views
  • 6 In Conversation
Gardenut
Luminary
Luminary
I accidentally logged out.  When I logged back in, it "upgraded" the App, and I'm now missing some of the special groupings I had.  Is it possible to go back to the "old" App?
34 REPLIES 34
Gardenut
Luminary
Luminary
NOW every one of my FIVE cameras are offline after adding them to Arm Home.  It doesn't matter what mode I set now, and I KNOW the batteries are fresh, and I've unplugged and replugged the modem!!!!  They have now become absolutely USELESS!!!!   IS THERE ANY PHONE NUMBER I CAN CALL TO GET HELP?
Gardenut
Luminary
Luminary
I don't know what's happened to my comments, they seem to get buried in the string.  I NEED HELP!  NONE OF MY 6 CAMERAS WORK NOW.  THEY ALL SHOW OFFLINE.  I'VE TRIED REPLACING BATTERIES, UNPLUGGING THE MODEM, AND NOTHING WORKS ON ANY OF THE MODES!  IS IT THAT MY TRIAL IS OVER (EVEN THOUGH I'VE NEVER GOTTEN THEM TO WORK SINCE BEING FORCED WITH THE NEW APP????)? I NEED TO GET MORE HELP THAN CHATS - THESE SEEM TO TAKE TOO LONG TO CONVEY IDEAS.  IS MY TRIAL PERIOD OVER?  IS THAT WHY NOW NOTHING IS ONLINE?   HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!
You can reach Arlo phone support using the app.
Gardenut
Luminary
Luminary
No I cannot, since my Arlos are old.
BrookeN
I see that two of the cameras are still offline. If you have done all troubleshooting steps and done a reset there is no further things to try. They have been EOL since 2023.
Gardenut
Luminary
Luminary
Yes, I FINALLY got 3 of them to sync, but I only have a day or 2 left on the trial, so I'm NOT going to pay for them, ot knowing how the new app even works.  They will go into the trash.
BrookeN
We can help you with any questions regarding how the app works.
Gardenut
Luminary
Luminary
Thank you, but I think it's too late.  Now that I got a couple of cameras to FINALLY work, I think my trial is (or is almost) over.  Is there a way to tell how much time is left?  What's the difference between arm away and arm home?
EOL cameras don't need a subscription. The trial sub you have is a marketing ploy to add features the free plan doesn't support but the expiration of that trial would mean your account simply reverts back to the original free plan. You can check the end date of the trial by viewing the subscription status in the app.
The various modes have names but that's basically unrelated to their actual usage. Arm Away automatically gets rules for every camera but you would need to add rules to any other mode that you wish to use. Usually, Arm Away would be used to Arm all cameras when you're away from home while Arm Home would only Arm certain cameras when at home (maybe turn off inside cameras). However, you can add rules to any mode to do what you want it to do regardless of the names. This FAQ may be useful to peruse:
https://kb.arlo.com/000062777/About-Arlo-Routines-Modes-Rules-and-Automations
Gardenut
Luminary
Luminary
OH!!!  Thank you SO much!  I guess I won't have to throw all of them in the trash...only 2 that I can't get to synch.  Thanks for the info!
