Hello,
I received the message to update the base station.
I tried 10 times even manually through the website.
it is not working.
I keep the same message that I should update.
basestation 1.10.0.9_23037
Please help.
Thanks and best regards
Stephane
Restart the base station and try again if it prompts you.
Hello,
Thanks for the feedback.
I retried today by restarting and reinstalling the update.
The base remains stuck in version 1.10.0.8_22190.. I do not have any error message neither.
It is annoying as it prompt often in the mobile app.
What can I do?
What is your internet up and download speed as reported by speedtest.net?
Dear Streak2,
Thanks a lot for the advice.
Arlo base station is on another wired network. I had an issue as it was slow.
The tricky point was slow but fast enough to get the pictures from cameras;
Problem solved !
Thanks a lot for your quick replies.
Best regards,
Stephane
