Whar do I need to do to rotate image tryed to reset the entire system and reconnect the camera but no good any ideas what I am doing wrong
Regularpa wrote:
Tried that but the invert button it is not highlighted think might have be a problem with my internet
Don't think its the internet iverting your image....
But the setting may be gliched in the base unit . If toggling the invert button doesn't work ( do a few times and seave each time ) then , If NG,
reset the camera by opening the battery door and power button reboot the base. Then remove the camera (SETTINGS>camera>REMOVE DEVICE) bring back camera as new.
Last, If still NG, you may have to re-set the base and then resync the cameras as if new
You invert the image in Settings, My Devices, your camera, Video Settings, Invert Image.
Nuts4Cats,
Consider a base station reboot (using the on-off button) and try again. Are you still seeing the same behavior?
